Is there a way to "left justify" the description header. Currently it appears to be centered. Really I'd like the "D" to be somewhere above the "cha", in the word mechanical below.
I see no justification options in the Appearance tab. I did find an "align text in column" (located in the ribbon) in your "HELP | Format a Schedule" link. That appears to do what I need. I had to add spaces to move it to the right, to where I wanted it. Also, It does not affect the rest of the schedule alignment / justification. I tested it to see if it affected the "Left, center or right" alignment, in the "formatting" tab. It did not.
Once aligned left you can then just add "spaces" before "DSECRIPTION" to get it to where you want.
Hi @DJHarrisEA6RG
Thanks a lot for posting your question to the forums! Have the solutions suggested by @barthbradley @HVAC-Novice @ToanDN @Mike.FORM helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
