The bottom two families shouldn't be included in this list, what's wrong here?
Just tested this. I can recreate this by adding a value to a filtered parameter, and then deleting the value.
"Has a value" is basically looking to see if a parameter is "null". You can't get back to "null" once you've put a value in. This is easy to see with a length parameter, for instance. It starts as blank (null), but once you put in a dimension, you can't make it blank again, only 0.
To fix, add another filter for "does not equal" and leave it blank.
In text parameters,
Considering you have edited that text parameter by clearing the text string in it "Done" or "Nested" , its current value became "" ie: Blank...you should notice that value in the drop down menu
Hence, you need to filter out the blanks to do that you can use either of the following conditions
