How can I have more then 8 filters why would they limit it to 8?
@Anonymous
You cant... you can only try to use smarter filtering and create a parameter which combines more than one condition... example: when an element Width is greater than its Height and painted red, its extra schedule filter parameter would read Santa
Filtering Santa out would act like 3 Filter fields on that dialogue
Why would you put a limit on number of filters, and not just have an "add filter" button so you can keep adding more filters. Lol why would there be a limit.....
It likely has to do with how the filtering in schedules is coded and the process slows down significantly once you get over 8 checks.
I bet it is related to the same reasoning that the filters still can only accommodate "and" conditions and not "or".
yea but all they have to do is actually code it. leftover from version 1 of revit and doesnt get enough likes on the idea forum to be implemented.
No, it is not you can make the variable for your group of objects and use as a filter and in your case with Keynote can you can use :
if you post all the list of your schedule with out filter or post a part of that, maybe we can find a way.
