Schedule does not calculate total correctly.
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
JKspace424
384 Aufrufe, 6 Antworten
I created a schedule for room area totals by floor levels.  I see that the 1st level total is correct but not the 2nd level.  The 2nd level seems to be calculated the 1st level instead.  How can I correct this?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: JKspace424
Is the schedule itemized?
Nachricht 3 von 7
JKspace424
als Antwort auf: ToanDN
I've checked the "itemized" box and unchecked it as well.  Does not change anything.
Nachricht 4 von 7
I didn't suggest checking or unchecking the box would fix it.  Is the image you posted from when the box is checked or unchecked?
Nachricht 5 von 7
JKspace424
the image I posted shows the "itemize" box as checked.
Nachricht 6 von 7
Wait a minute.  I gave it a calc and the result is 1,640.  So 1,642 should be correct given some rounding happening.  How did you come up with 1,462?
Nachricht 7 von 7
JKspace424
oops.  You're correct.  I must have missed a number or two.
