As in pic I would like to hide total of length but show total of volume.
Is it possible to customize the footer totals?
On your formatting tab, is your DÉLKA parameter set to calculate totals? If it isn't, it should show like this:
both parameter are set as "Calculate totals" because I want to see the total lenght per each type.
The Footer is set as "Show only totals", but I want to hide the DELKA (lenght) total in the footer.
Is it possible somehow?
Under 'Sorting and Grouping' check 'Grand Totals' and under formatting you can determine if the totals are calculated for each category - see attached image.
In pic enclose you can see the result I want to achieve.
