Schedule apartment types by floors
15 ANTWORTEN 15
Nachricht 1 von 16
Pierluigi.Glicea
725 Aufrufe, 15 Antworten
I'm trying to create a schedule that would summarise the apartment types. This would make our client's life easier.
I'm attaching a picture to clarify my intentions.
Can anyone help me with this? I'm struggling with the apartment types counts.
Thank you very much
Tags (1)
15 ANTWORTEN 15
Nachricht 2 von 16
als Antwort auf: Pierluigi.Glicea
Post your Project file here as an Attachment to a Reply Post.
Nachricht 3 von 16
Yes it can be done easily with Room or Area schedule, depends on what you use to define apartments in the model.
Nachricht 4 von 16
Pierluigi.Glicea
als Antwort auf: barthbradley
Thank you for your reply,
I don't have a project to show you at the moment since I'm creating a template that would suit the office's future needs.
Nachricht 5 von 16
Pierluigi.Glicea
als Antwort auf: ToanDN
Could you please explain how to manage the columns to me?
Much appreciated and thank you for your time
Nachricht 6 von 16
Well then, all's I can say is that it can be done.
Nachricht 7 von 16
I can if you share a sample model with some apartments.
Nachricht 8 von 16
Pierluigi.Glicea
Thank you! I'll create an example and link it here if it's ok with you.
It won't be a real project but I believe it will suit our needs.
Nachricht 9 von 16
linkboy
@ToanDN
I have a similar question, made a sample model attached. Below is the schedule try to work out, added % to show each type unit vs. all units. thank you,
Nachricht 10 von 16
als Antwort auf: linkboy
Something like this.
Nachricht 11 von 16
linkboy
Can we combine 1BR-A + 1 BR-B = 1 BR?
Nachricht 12 von 16
I would use 1 BR for name and A or B as Comments.
Nachricht 13 von 16
linkboy
That works for me! Thank you @ToanDN  . I did not start the post, cant accept this as solution.
Nachricht 14 von 16
Pierluigi.Glicea
The schedule you attached is exactly what I'm looking for.
I would like to have unit types on columns and levels on rows if possible.
Nachricht 15 von 16
linkboy
I have units #, area and ADA requirements in the schedule, but not able to switch the row/column of the matrix. Like to see that happen, not feeling it is necessary.
Nachricht 16 von 16
Pierluigi.Glicea
unfortunately I really need to switch between columns and rows as I showed before.
Hope someone could help
thank you
