Schedule and elevation
9 ANTWORTEN 9
Nachricht 1 von 10
FRAN1972
475 Aufrufe, 9 Antworten
Hie,
I must do a schedule with a count of building glasses of only one elevation of a building. I am going to do a schedule with the family_type, width, height but i don´t know how to take only the glasses that belong to that elevation. How do you recommend me to do it?
Regards.
9 ANTWORTEN 9
Nachricht 2 von 10
Ryan_GormanKT36T
als Antwort auf: FRAN1972
I think this is what you are looking for;
Help | Filter Schedules by Sheet | Autodesk
Nachricht 3 von 10
Ryan_GormanKT36T
Nachricht 4 von 10
FRAN1972
als Antwort auf: Ryan_GormanKT36T
Thanks so much! The problem is that option non t appear in Revit 2021.
Regards.
Nachricht 5 von 10
Filter By  Sheet doesn't work. Your are going to need a workaround. One workaround would be to Filter a Panel Schedule by a comment or mark that indicates what compass direction the panel faces.
Just to be clear: I will need a Duplicate Schedule for each compass direction. North, South, East, West.
Nachricht 6 von 10
FRAN1972
Done! Thanks a lot.
Do you know if exist a way to export that partial schedules to excel?
Regards.
Nachricht 7 von 10
Alfredo_Medina
Go to the schedule view. Then > File > Export > Reports > Schedule > then create a  .csv or .txt file. Then open that file in Excel.
Nachricht 8 von 10
FRAN1972
als Antwort auf: Alfredo_Medina
Thanks but i don´t want to export the complete schedule if not the schedule filter by sheet.
Regards.
Nachricht 9 von 10
Alfredo_Medina
I understand that this is not possible with the built-in tools. I saw en LinkedIn that someone posted about a Dynamo routine that can do that.
Nachricht 10 von 10
Export the sheet to PDF. Open the PDF in Adobe or Bluebeam, crop to show just the schedule, then export to Excel.
