Schedule ALL Revit elements in one table
femi.osewa7PFZ4
femi.osewa7PFZ4
I need to be able to schedule all model elements regardless of category. I'm finding this to be a little troublesome- but since Revit assign ID to all elements, we should be able to have a table that list all elements
RDAOU
@femi.osewa7PFZ4
Did you try the multi Category schedule?
Have you set schedule's phase/phase filter to capture all the elements you want?
femi.osewa7PFZ4
As far as I'm aware this does not cover the system families such as walls. It will be good to be able to have all of these elements from different categories at least for QA/QC purposes
You can export to a database using Revit DBLink.
constantin.stroescu
you can gather all these info by using Dynamo....as in my example
use a 3d View so to be able to select all the model entities (using Window or Cross Selection) , and use Dynamo to save as a .csv list or export to Excel..
Constantin Stroescu
femi.osewa7PFZ4
Thanks for this, I was actually asking why we cannot schedule the categories using the built in schedule. It will make it easy for QA QC process
