Schedule All objects in the model
markfarrell
markfarrell
I need to create a schedule that lists out all the objects in the model, is this possible?
I have tried Multi-category but it misses some of the objects (in this case walls and slabs), when I export to IFC and analyse it missed 60 objects.
Thank you
hmunsell
  1. Make a project parameter, i called min EXISTS
    1. Assign it to ALL Categories
  2. Make a multi-category schedule
    1. Assign EXISTS, Family and Count to it
    2. Filter by EXISTS, Has No Value
Howard Munsell
markfarrell
Thank you. Just Tried and it still did not pick up all the objects.
The parameter was added to the all objects, but when i choose multi-category, it still does not add those objects to the schedule, in this case it is structural model and it is failing to find walls and slabs.
If select a schedule just for walls with the same fields then it finds all walls which are not in the multi-category schedule.
Thank you
hmunsell
did you check all the discipline options when selecting the categories the Project Parameter?
Howard Munsell
markfarrell
Thank you.
Yes, all elements have been selected, and it still misses some of the Objects.
