Hi everyone. I have 3 type of walls in a project. I want to have a wall schedual and underestanding the total length for each type seperatly.Is it possible?
Gelöst! Gehe zur Lösung
Hi Ghassemi_eh
yes this is possible, follow the steps defined below:
- create a wall schedule
- add the fields, "family", "Type" and "Length"
If you don't see the totals, you have to sort and group your schedule.
In the properties window for your wall schedule there's a sortting and grouping button. hit the checkbox itemize every instance.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Ron van Grinsven
Cadac Group AEC BV
Thanks friend. But I see the totals .I want to see the totals for each type of walls.Like this
alright, to add the totals per type of wall, follow the next step.
- on the sorting/grouping tab, hit the footer checkbox and choose your desired totals.
Kind regards,
Ron van Grinsven
Cadac Group AEC BV
Is there a way to have one line per wall type with total length?
See attached image; notice the length is only given for the wall type with a count of '1'.
Disclamer: this is in progress; replacing "type" with "mark" or whatever; it'll match the mark in the drawing when I'm done.
Thanks!
Bennett
Okay, I found it. It's under the 'Formatting' tab instead of the parameter properties in the 'Fields' tab. There's a drop-down list of options with "standard" at the top.
Thanks!
