Scalling a view from a sheet environment in specfiic direction(s)
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
ArthurADas
708 Aufrufe, 11 Antworten
Is it possible to control in which direction my object is going to scale when i change the View Scale?
Something like the image attached?
Arthur
11 ANTWORTEN 11
Nachricht 2 von 12
RobDraw
als Antwort auf: ArthurADas
It should be but sounds tricky depending on the element.
Rob
Nachricht 3 von 12
Arthur
Huh?  Trying to wrap my brain around this one since objects don't scale when you change the view scale.
Nachricht 4 von 12
It generally scales NE direction.
Nachricht 5 von 12
RobDraw
als Antwort auf: barthbradley
Annotation symbols do.
Rob
Nachricht 6 von 12
ArthurADas
Hey @barthbradley
Im attaching 2 files to demonstate what i mean
Nachricht 7 von 12
als Antwort auf: RobDraw
Thanks! Got my brain wrapped around it now!  And yeah; it would be nice if you could control that.
Nachricht 8 von 12
ArthurADas
@RobDraw
Well, it is just a Generic model family, no annotations or symbols.
In those two prints attached here you can see that when i change the scale my object changes his size, but also moves away from my View Title. I'm trying to find a way to pin a origin point in order to make my object grows/shrink without moving away from my View Title.
Nachricht 9 von 12
The view grows when you change to larger scale.  Turn on the view crop region and you can see it.  The view title is an annotation so it remain the same size and location on sheet.
Nachricht 10 von 12
als Antwort auf: ToanDN
This is what I thought we were talking about...
Nachricht 11 von 12
ArthurADas
@ToanDN
Thanks for your explanation, it helped a lot to understand what is happening to what when i change the scale.
Hmm, so the View grows and the object follows. Maybe the solution would be to pin one point of my region view instead of my object and, when i change the scale, that point will be fixed in my sheet and its going to grow to those directions that are not pin?
Well, is it possible? Did i get the right idea? :denkendes_Gesicht:
Nachricht 12 von 12
RobDraw
"Sometimes you get a poorly worded question and sometimes the question gets you."
That was quite the rabbit hole we had to navigate in order to get to the meaning of the question.
You want to change the scale of a view/viewport and be able to choose the base point by which the boundary gets scaled to accommodate the new scale. This cannot be done as we have no control over the viewport on the sheet aside from position and type.
Rob
