Scaling down the purlins
4 ANTWORTEN 4
Nachricht 1 von 5
jinergoh721
207 Aufrufe, 4 Antworten
Hi all,
I'm trying to scale down a <detailing line group> ( I drew it with annotation lines), but see it's forbidding me to do so, how to fix it up?
thx
Jiner
have a nice day. :leicht_lächelndes_Gesicht:
4 ANTWORTEN 4
Nachricht 2 von 5
jinergoh721
als Antwort auf: jinergoh721
I've also tried ungroup the detail lines and scale it down, but it keeps prompting me " line is too short,"
TQ
jiner
Nachricht 3 von 5
rxi.gg
Model lines in Revit have a minimum of 1/32" in length
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-er....
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 4 von 5
se.ha
Hi @jinergoh721,
as @rxi.gg mentioned there is a minimum length for lines.
Try deleting the elements when prompted and then simplify the geometry to close the resulting gaps.
At this size noone will notice if the edges are beveled or not.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Nachricht 5 von 5
TQ
jiner
Simplify the shape and get rid of segments too small.  Also, Revit is not for the intent of modeling everything of their actual sizes, for example: thin metal elements such as steel framing or corrugated siding.
