Scale parameter in tittle block
7 ANTWORTEN 7
Nachricht 1 von 8
yes_and_no
577 Aufrufe, 7 Antworten
I was under impression that the scale parameter in tittle block would report the viewport scale, and when there are two viewports it will report "as shown".
But I was wrong, sometime I have only one viewport on the sheet, it still report "as shown".
Did I miss anything ?
7 ANTWORTEN 7
Nachricht 2 von 8
chughes
als Antwort auf: yes_and_no
This occurs when you have two views at different scales on a single sheet.  Revit has no way to correctly report the scale of the views, so it simply says to check the specific view for the scale.  If all views on the sheet are the same scale, the title block will indicate the correct scale.
Have you confirmed just the single view is in place?
Nachricht 3 von 8
Do you have any legends on the sheet?
Nachricht 4 von 8
So, your Titleblock has a Label that reads the "Scale" Parameter and, in the Project, that TB Label reports "As Indicated" when there is only one View placed on the Sheet?
...or, to put it another way: when you press the "+" sign next to the Sheet name in the Project Browser, you only have one View listed under that Sheet name?  Which one?
Nachricht 5 von 8
yes_and_no
als Antwort auf: ToanDN
I have drawings with single viewport and multiple legends, yet it reported well.
Some didn't (yes Rhadou, I did delete and reinsert the view).
Nachricht 6 von 8
But are the view and all the legends in the same scale?  Bet they aren't.
Nachricht 7 von 8
yes_and_no
No. All my legends are 1 to 1. Most plans are 1/4"=1'0". Maybe I should change all my legends to 1/4" ?
Nachricht 8 von 8
When you say "Legend", you mean Legend/View - not a Color-Fill Legend; right?
