Hi All
I have drawn up some details over the model view in 1:20 using detail lines and fills. I group them together and copy onto the 1:5 sheet. The model lines are scaled but my detail lines become very thin.
Do I have to manually adjust each line or there is a quicker way ?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Annotation Detail lines sounds a little bit confusing it is
If you are missing the Scale 1:5, then you need to Add it otherwise the closest defined scale will apply (ie: 1:10)
The line weight of "detail line" is controlled by Model Line Weights not by Annotation Line Weights.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
