Hello, can i put two vies in a plan, with diffent scales and in the information get the two scales instead of the message (como se indica two times) sorry it is in spanish? Thanks
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Hi @Anonymous ,
I'm afraid you cannot do that in Revit automatically. It will always display "As Indicated" in english when there are different view scales in the sheets.
The workaround is you should do it manually using text.
Darwin
no, you can't, the only way is to duplicate your view and scale your annotation text. thanks
in order to overcome this problem ,
For me, at least, this method is quite useful in practice.....
https://knowledge.autodesk.com/community/screencast/4cc9115d-3e3f-4713-82f3-e4f7a7f53a75
Constantin Stroescu
