Scalable generic family ?
dcarlsen8GY35
Message 1 of 17
dcarlsen8GY35
Have searched this - haven't found the straightforward answer yet. Has this been straightforwardly implemented yet ?
Replies (16)
Message 2 of 17
Modify a RCP tree family maybe.  Those are scalable.
Message 3 of 17
SteveKStafford
Assuming by scale you mean arbitrarily making a family x times bigger or smaller and since you wrote straightforwardly... then no.
If you're open to how it can be done, then the planting category can be scaled. There are numerous examples of doing it that way, here's one.
Steve Stafford
Message 4 of 17
zhaohui.chen5TEA7
Thanks.
Is there a way to create scalable annotation families?
Message 5 of 17
SteveKStafford
Short answer no. Longer answer... you can create different types and use parameters to change the size of graphics and swap one size label (text) for another size. They won't respond to a view scale other than to maintain whatever size you designed into the type you placed.
By design, annotation families are created using a printed size in mind. They are not intended to increase or decrease  in size because annotation symbols conceptually should always be the same size regardless of the view scale they are seen in.  A North arrow shouldn't be smaller in 1:100 views than in 1:50 views, at least that's a common perspective on symbols.
Btw, asking a specific question like, "I need this thing to do that", instead of deciding in advance what the very broad answer (scaling) should be to solve it, might help provide a better answer.
Steve Stafford
Message 6 of 17
zhaohui.chen5TEA7
Thanks a lot Steve.
If the annotation family is simple like a circle or a square, it's very easy to make the family "scalable".
If the annotation family contains more complex elements, sure it still can be made "scalable" by doing a lot of mathematics and adding complex parameters & constrains to each element. Obviously this is not ideal.
I believe Revit (Autodesk) definitely has the ability to provide such simple functionality. Actually, Revit already has the functionality in itself (such as planting category element), Revit just doesn't give user the ability to control the scaling. Or, there may have some good solutions / work around like using planting category for model family, which I don't know and want to learn from advanced users like you. This is my question coming from.
Thanks & Regards
Message 7 of 17
What exactly the annotation family is for and what are the circumstances that you need to scale it?
Message 8 of 17
zhaohui.chen5TEA7
Message 9 of 17
XXalessio.amodioXX
For this purpose I would suggest you to use the functionality : Detail group.
I had the same issue and It helped me.
Message 10 of 17
zhaohui.chen5TEA7
Thanks  alessio.amodio
I think it is a very good solution.
Regards
Message 11 of 17
XXalessio.amodioXX
Please mark the answer as solution to help further users that might have the same problem.
Message 12 of 17
zhaohui.chen5TEA7
I'd like to mark the answer as solution 🙂
However, I couldn't find the "Mark as Solution" button or something like that. Could you show me how to do this? Thanks.
Message 13 of 17
Only the OP can mark the solutions. Create your own topics then you can mark solutions yourself.
Message 14 of 17
zhaohui.chen5TEA7
I see. Thanks
Message 15 of 17
zhaohui.chen5TEA7
How do you scale "Detail Group"? I found that the scale button is grayed out when I try to scale a detail group.
Message 16 of 17
XXalessio.amodioXX
Just edit type and create a new group with desired dimensions.
Message 17 of 17
zhaohui.chen5TEA7
Thanks alessio.amodio for your quick response:)
Good tip! I think I can do similar thing in families too.
