Hello friends,
I want to produce the pictures in Revit.
How should I follow this?
Is it necessary to produce all of them individually?
I want to present the scaffolding system in terms of quantity and visibility.
Warm Regards.
Gelöst! Gehe zur Lösung
Gelöst von FGPerraudin. Gehe zur Lösung
Agreed,
Create families separately and then nest them.
Don't forget to tick the "shared" box in the category properties panel for quantifying (Create > Properties > Family and Category parameters)
Idealy, make a few strategically designed repetitive and parametric host family with swappable components that hosts your components and has a few basic layouts integrated
It might take you a while but the time saving would be amazing if used in the long run for presenting different configurations for projects.
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
HI, Any progress with your scaffold family? Take a look at mine, I am no Revit Expert so feedback welcome! I intend to add more so please consider this a WIP.
You guys sure are making fantastic scaffolding in Revit. No doubt about that.
Is there a business purpose? Or are you just doing it for fun and practice?
I would think a simple box shape could be adequate to lay-out scaffolding on a construction drawing. No?
Hi, thanks! Partly for fun and practice but also potential business use. I work in a multi discipline practice Arch, Structural, Civil and Temporary Works. The Structural and Architectural BIM advancements have left the TW outputs looking 'old hat'. I am trying to bring the TW output up to date and do something a little different.
It makes sense in the context of a presentation drawing for a client, or something like that where you really want the pop of detailed reality to impress people.
The only reason I asked is because I'm fairly strongly in the camp of, "Just because you can doesn't necessarily mean you should." If your end game is simple construction drawings - just for example - why make the drawing more cluttered than it needs to be, and why make your file size any heavier than it needs to be. Know what I mean?
