I was wondering if there's a good method for modelling bespoke brickwork, such as a sawtooth panel? Usually I'd be satisfied with a 2D hatch but the sawtooth has a distinctive shadow profile relevant in both my elevations & renders, & will be visible in my plans too hopefully. Would it be a case of modelling the whole panel as a generic model family, then placing it into position? The
Also I have a flemish bond brickwork pattern with projecting snap headers. I imagine modelling this would be pointless as this bond wraps around many walls and is punctuated by windows. Is there any way to give the appearance of projecting snap headers through a shadow profile etc? Ideally I'd like it to be visible in both elevation views and renders.
(Screenshot examples of both bonds attached)
Many thanks,
Sam
You can use curtainwall panel to create the look you want. See attached.
Maybe embed a Curtain Wall into a Basic Wall. The Brick would be the Vertical Mullions, angled 45-degrees.
For the second brickwork, you have to use curtainwall to create the look you wanted.
