Saving revit model with linked files as one file
4 ANTWORTEN 4
Nachricht 1 von 5
m_hunt-RDA
714 Aufrufe, 4 Antworten
Hi everyone,
We have a revit model that contains multiple linked files for various blocks. Is it possible to save a copy of this where the model can now act as if it wasn't linked files?
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: m_hunt-RDA
You could bind the links but be aware that phasing in the links would be eliminated.
Nachricht 3 von 5
Why? Kind of defeats the purpose of Linking. No?  Instead, why don't you just transmit with the links included?
...binding the links is easy, but that would be followed by "mitigation" work - if you catch my drift.
Nachricht 4 von 5
m_hunt-RDA
als Antwort auf: barthbradley
We have 6 models and someone has suggested trying out changing the window size which is consistent across them all. Would save making the change, which won't be implemented as it will look awful, in 6x models.
Nachricht 5 von 5
se.ha
Have you tried using eTransmit? I found it to be a very easy and fast solution in creating one model with multiple bound links.
eTransmit for Revit | Revit 2022 | Autodesk Knowledge Network
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
