Saving a project as a template
3 ANTWORTEN 3
Nachricht 1 von 4
kherrman
359 Aufrufe, 3 Antworten
Autodesk says I should be able to remove work sharing from a project and then be able to save the project as a template. I do this but the save as template option remains greyed out.
3 ANTWORTEN 3
Nachricht 2 von 4
Tom_Kunsman
als Antwort auf: kherrman
You will need to save the file as detached from central , and remove all worksets as template files can not have worksets saved in them.
Nachricht 3 von 4
How did you remove worksharing?  Open detached and disregard worksets?
Nachricht 4 von 4
Tom_Kunsman
als Antwort auf: ToanDN
@ToanDN yes, disregard worksets (which I think is the bottom option)
