saved project file lost.
6 ANTWORTEN 6
Nachricht 1 von 7
778 Aufrufe, 6 Antworten
 when I opened Revit the file was saved on the home screen under projects. it is Not there anymore how DO I gain access to this file.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Check between the sofa cushions -- that's where I usually find stuff.  Smiley (zwinkernd)
Serious though -- it just sounds like it was moved from the location it was saved to. Have you tried a search?
Nachricht 3 von 7
als Antwort auf: barthbradley
I cant seem to find the project file anywhere. It was saved and now it has
seemed to disappear! really frustrating. do you have any clue to where it
could have been relocated to?
Nachricht 4 von 7
I'd just let Windows search the whole hard drive for it  -- while I enjoyed another beer.
Nachricht 5 von 7
I found it but apparently it saved as a shortcut. The shortcut says it can
not open. how do I make this file not a shortcut?
Nachricht 6 von 7
RobDraw
You can't.
Are you on a network?
All you need is someone with a little advanced knowledge of computers to do a search for you or maybe you can look-up how to search your hard drive.
Rob
Nachricht 7 von 7
Sahay_R
Search your hard drive for Revit files by typing *.rvt in the highlighted area.. This will pull all the Revit projects on your hard drive (or wherever it is that you save your files)
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
