Save Issue Revit 2016 (Revit 2016 trava ao salvar)
5 ANTWORTEN 5
Nachricht 1 von 6
358 Aufrufe, 5 Antworten
I recently downloaded Revit 2016 for students, but I was not able to use it once. When I click on "save" the program hangs (does not respond) and the only option is to close it, losing everything I created.
I've tried some solutions that I found in the Autodesk Forums, like this:
https://knowledge.autodesk.com/en/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/ENG...
I also tried reinstalling the program, disabling the anti-virus, firewall, with no results.
Any solution ??
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Are you saying that Revit successfully launches, but when clicking Save the program crashes or freezes?
Nachricht 3 von 6
als Antwort auf: barthbradley
Exactly!!
Nachricht 4 von 6
Nachricht 5 von 6
I did steps 1, 2 and 3, with no result. Step 4 I tried now, but I didn't understand which server service to find in the Services.msc folder...
Nachricht 6 von 6
When you did a re-installation, did you first perform a "Clean Uninstall"?
 https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
It may be worth a try, however your situation is unique, in that you can actually launch the Product and work on it.
Let's see if @Viveka_CD  can assist.
...one other question: do you have a bone fide Student License?
