Hello all,
In a project I regularly receive the message that the central model is not accessible. Now I want to solve this problem by saving this central model as a new project.
However, in the save as options I cannot select that I want to make this a central model after it has been saved. This option is, just like compact file and "open workset default" greyed out.
How can I avoid this?
Thank you
Gelöst! Gehe zur Lösung
Gelöst von Zalmenlm. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
This wasn't possible because I didn't was the owner of the file. I had to change my name into his name. After that, it was solved.
Thank you
First, save the file as 'Template', then create a 'New project', choose the template you just created, and then 'save as project'.
