Save All Open
3 ANTWORTEN 3
Nachricht 1 von 4
paullimapa
1076 Aufrufe, 3 Antworten
Save All Open
Is there a Save All Opened Project File command in Revit?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
3 ANTWORTEN 3
Nachricht 2 von 4
Corsten.Au
als Antwort auf: paullimapa
Seems tough to get this done.
Imagine you opened a read only or detached file of a central and created..
while saving that file, Revit needs to know a new location..and simple save command
wont work even if it was automated which closing revit..
So Save all open wont work in many cases....
When you have opened multiple files and have not done any changes.. then
revit will close without giving any warning to save..
but if file has been modified or edited , then its fair enough to let revit know which one to save and
which ones not...
Hope that helps
Cheers!
Corsten
Building Designer
Nachricht 3 von 4
paullimapa
als Antwort auf: Corsten.Au
Thanks for your feedback.
Well, I don't mind any of the prompts.  But if I have multiple Revit files opened, and none of the situations you mentioned applied, I would really like to just click SaveAll or SyncAll once so I don't have to sit there and wait for the command to complete before cycling to the next opened file to repeat the command.
Paul Li
IT Specialist
@The Office
Nachricht 4 von 4
Most users are not working in read only file or detached file most of the time.
Very likely to have multiple projects open from the cloud though. or multiple families open while editing.
Or reloading nested family in multiple projects at a time.
these cases would be great to have a save all open button at once.
