SAT Import to conceptual mass material problems
Hi all,
I realise this is a very common question but I have a problem that I can't seem to find a solution to.
I've created a conceptual mass and imported a SAT file from an exported Rhino model - it's a piece of site context. The override of the material via the Object Styles is fine but when I load it into a Revit Project file it loses that material override and is back to the translucent default...
I've noticed using the paint tool works, but there must be a more elegant solution to this....
Any clues?
Thanks in advance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi Craig,
Please check display settings
Rafal Gaweda
Actually I clicked Solved too early, this doesn't work. The family conceptual mass still requires using the paint tool to colour. Changing the material in the Object styles makes no difference.
