SAT. files into Revit LT
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2013 Aufrufe, 4 Antworten
I'm using Revit LT and need to import an ACIS object in either a DWG or SAT file.  I can't find the category in the drop down menu. Is this a difference between Revit LT and Revit?
4 ANTWORTEN 4
Nachricht 2 von 5
DarrenP
als Antwort auf: Anonymous
do you see this:  insert tab>link CAD or insert tab>import CAD
DarrenP
Nachricht 3 von 5
als Antwort auf: DarrenP
yes but i want to import a ACIS object, preferrably SAT. file and that option isnt showing up.
Nachricht 4 von 5
DarrenP
In Revit you can bring in .sat files this function must not be in Revit LT
DarrenP
Nachricht 5 von 5
Open the SAT file in AutoCAD and save it as a DWG.
