I made labels to use on sheets, like Approved by and so on.... in our language but why is not possible to delete the build in parameters that come with sheets because it is comfusing to have both on sheets ???
If I use the build in parameter why is it not possible to use Sample value or change the Parameter name ???
We want to use our language not english names!
Is Revit not available in your language?
You can't remove or rename the build in ones, but what exactly is the problem with these? You can fill in the name of the person who did approve? That is not language specific? On the sheet you can just use text and place a label next to it.
In the Properties window there is the build in parameters in english and than we have the other that we made in our language, annoying to not be able to use the same name for these fill forms as we are use to in Autocad frames.
I made our own parameter but than I cant get rid of the build in ones so it is confusing for people to use !!
Unfortunately, Revit different from AutoCAD. It is not to your liking, but the best solution is to use the build in parameters which are shown in the properties palet. On your sheet you can use your own language for text to indicate fields.
