I used exactly the same vie template, in the 3D views its shows the red mass as transparent as I want it, but in elevations it does not show transparency. I implemented trancparency in the material..
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Hard to tell without anything to inspect...here it seems to work fine (See GIF below)...Any Phasing filter?
If all fails and it keep bugging you, override transparency via filter or category. This cannot fail
For presentation, instead of using a true 2D view, create a 3D view and change the orientation to match your 2D view.
