Is it possible to have the name on sections when the view is placed on a sheet?
2 different sections can not have the same name. You can use the Reference Other View option though to place a section and have it point to another, already created, Section.
Howard Munsell
True, but the example shows what looks like a section number not the section on a sheet with a View Title :-).
Howard Munsell
Your answer is in post#2; Reference other view when drawing a section. Another option might be using a View reference under View - Sheet composition.
Hi @Anonymous . You can insert unicode characters in the name and then they will be displayed with the same name. But this can only be done if the option from the second post is not suitable for you.
Best regards, Pavel Plotitsyn.
