hello,
i having trouble with this for whole day now, it seems that no matter what i change the properties of the floor (the brown one) it remains as brown. but the other floor (the light colored one) i can change it to any floor property.
hope you can help me with this problem. thank you in advance.
jv
Gelöst! Gehe zur Lösung
Hi
check floor properties
1: floor
2. Edit
3 top most layer
4 check material
5 that material properties
( material shows different when the view is hidden, coarse, fine, shaded, realistic etc )
this material colour depending on the view dominates over other properties .
for example room, room colour legend , room colour legend won’t show if floor top most layers material is given colour, hatch etc..
hope that helps.
cheers
already found the solution. since this file was sent to me i didn't know its history.
the problem is, the floor are painted. simple remove paint is the solution.
thank you for the reply.
