Same fill pattern displaying differently in different projects files.
1 ANTWORT 1
Nachricht 1 von 2
mariaZW9XM
260 Aufrufe, 1 Antwort
I have a fill pattern for wooden surfaces and it displays differently. I have copied the one on the right into the file on the left and I don't know why the pattern is different (see image). Does anyone know why this happened and how can I fix it? I would like to have it as in the file in the right.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: mariaZW9XM
Rename the Fill Pattern and try again.
...if this is a Family being brought into a Project, keep in mind that Project Materials RULE.  That is, if a names are identical, the one in the Project will be used.
....Use Transfer Project Standards between Projects.
Transfer Project Standards | Revit 2021 | Autodesk Knowledge Network
