Same demolished roof appears normal from above
5 REPLIES 5
cscott12ZX5LX
291 Views, 5 Replies
See below. Both views have same phasing settings but the left side roof isn't appearing as demolished in the roof plan higher up. Why is this happening?
5 REPLIES 5
Make sure your Phase Filter is showing overriden demolished elements, also check filters and VG.
I solved this problem by using plan region over the roof and cutting at the 2nd floor level like the view to the right
in reply to: cscott12ZX5LX
Extend the view range bottom to cover both roofs.
cscott12ZX5LX
in reply to: ToanDN
It was
cscott12ZX5LX
in reply to: ToanDN
So changing view depth didn't fix it but changing bottom range did
