Have anyone had experience doing Log Cabin using Saddle Notch system?
Creating a screencast will be very helpful.
I will use Round Profile, not D or Square shape.
I have Revit LT so I can't use components to insert windows or doors, so I would only do the log modeling without windows or doors. My client wants to know how it works to add new space to existing cabin using same Saddle Notch system.
Gelöst! Gehe zur Lösung
Gelöst von WFTDesign. Gehe zur Lösung
I think this is a very interesting task.... I would try this with a curtain wall. I would create a curtain wall profile to describe the profile of wood elements and then use it to create custom curtain wall mullions. Then, I would position grid lines close together with a "Fixed Distance" or a "Fixed Number".... So, every horizontal grid line would be a hosting a wood element.
I never tried Revit LT, so I don't know if you can load profiles there... If you can't, you can always try this with an in-place family.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
@barthbradley: thanks! ![]()
Andrej Ilić
MSc Arch
