S-Bend Beam Meeting at Tangents
4 REPLIES 4
rsmarrelli
425 Views, 4 Replies
I'm trying to make a beam that follows this curve:
This curve is sketched on a work plane defined by a grid line. The beam goes on the same plane with a slight Yoffset.This curve is sketched on a work plane defined by a grid line. The beam goes on the same plane with a slight Yoffset.
So, I get out the beam tool, I choose the "pick lines" drawing option, and I click on one of the curves. I get this:
So far so good. That's exactly what I expect to happen. We have half of the curve down, so I click on the other half and this happens:
Why on Earth would Revit assume that this is what I want to do? If I select either beam it has the audacity to tell me that the extension/cutback is zero on both ends. It's just decided to draw the beams on some imaginary curve other than the one that I picked. And no, there are no other curves that could have been selected by mistake. Certainly none that would make this result make sense.
If I try to draw the beams using the other draw tools the same thing happens. If I try to move the shape handles to get closer to what I indended, I can't actually snap to the tangent point between the two arcs. When I try to eyeball it, I get this:
It's not snapped to the tangent point, and I can't make the edges of the beams join up despite the fact that the curves themselves are tangent to each other.
So, how do I go about just making a beam based on that original curve in the first screenshot?
Labels (3)
4 REPLIES 4
in reply to: rsmarrelli
What's that green line?  Are you sure the Beam is actually following that line?
Why not sketch the Beam with Spline?
Edit Beam/Column Join?
rsmarrelli
in reply to: barthbradley
So, this is embarrassing, but my actual problem was that the model lines I based it on were imperceptibly off-tangent. It all worked once I fixed that.
Now, this still doesn't explain why Revit makes the assumption that I want to curve the beams in the opposite direction, and your suggestion about beam/column joins may address that, but I don't really have time to experiment with it.
Thanks anyway for the suggestions.
I think you may have an easier go of it by doing the Beams outside of Group Edit Mode and Adding them to the Group afterwards.
BTW: Beams have a direction. That's in their DNA, so to speak.
Forma Design Contest
Technology Administrators
