Hello All
I converted a sheet from rvt to dwg. Revit unit is set to mm, export to dwg setting is set to mm. Dwg unit is correctly converted to mm as well. However, dwg viewport predefined scales are in inches. any ides on how to resolve this?
thank you
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
Welcome to the Autodesk community new visitor! ![]()
Please see the below two posts:
https://forums.autodesk.com/t5/autocad-forum/primary-and-alternate-dimension-units/m-p/7182835
Let me know if this helps.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
