Hello
For inquire total editing time of certain project file, AutoCAD has a TIME command, which shows elapsed working time with this file. How can I find the same information in Revit project file?
Best Regards
Gelöst! Gehe zur Lösung
Gelöst von Richard.P.Garcia. Gehe zur Lösung
Thank You, @Richard.P.Garcia
I see. I'll try to find addin suitable for this function in Autodesk app-store. Thanks for advice.
Best Regards
Hi @Anonymous,
You are welcome. I believe you can find addIns that is suitable for you. ![]()
Please hit the "Accept as Solution" button if my post resolves your issue and give "Kudo" as appropriate.
