RVT.msi
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
20477 Aufrufe, 11 Antworten
RVT.msi
Hi
I work on Revit 2019 but to update it I need the file ''RVT.msi'' which is located to      C:\Autodesk\WI\Autodesk Revit 2019\x64\RVT\
But i've delete it, can someone send it to me please ?
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
Nachricht 3 von 12
DarrenP
its looking for the install files
you will need to download & extract the files again to that location
DarrenP
Nachricht 4 von 12
als Antwort auf: DarrenP
just curios where the OP needs to go to find the appropriate resources?  If not AVA; Where/how?
Nachricht 5 von 12
DarrenP
als Antwort auf: barthbradley
ava or their autodesk account
DarrenP
Nachricht 6 von 12
Basam.Yousif
Can someone please just upload this file here?
Thanks!
Nachricht 7 von 12
als Antwort auf: Basam.Yousif
@Basam.Yousif
C:\Autodesk\Revit_2019_G1_Win_64bit_Trial_dlm\x64\RVT
Nachricht 8 von 12
JanisGrf
BTW - got the same problem but there was RVT.msi missing as I tried to reinstall Revit ... and found the missing file in: C:\Autodesk\{A42C7897-B448-4717-A23B-48C7A99E9EB5}\image\RVT_2023_en-US\x64\RVT where the installation unzips from installer... that fixed the problem.
Nachricht 9 von 12
Sandra.Brzeska
als Antwort auf: JanisGrf
Thanks for this!!!
Nachricht 10 von 12
201803709
GRACIAS
Nachricht 11 von 12
josephandersonacevedoalvino
Para que de resuelva el problema, tienes que desinstalar el Revit que cuentas desde el panel de control de tu ordenador, si en caso no pudiera desinstalar: prueba con la pagina de Elimine Autodesk. :zeigefinger_nach_links:
Una vez realizada la desinstalación,  instala la versión del RVT.
Fig. 01: Vista del Problema
Nachricht 12 von 12
Basam.Yousif
Not a good idea!
Do not uninstall Revit because it may be very difficult to reinstall. Do that only as last resort when nothing else works.
Modern versions of Revit (2021 and after) are almost impossible to reinstall. You have been warned :strahlendes_Gesicht_mit_lächelnden_Augen:
