RVT.msi
RVT.msi
Message 1 of 12
RVT.msi
Hi
I work on Revit 2019 but to update it I need the file ''RVT.msi'' which is located to      C:\Autodesk\WI\Autodesk Revit 2019\x64\RVT\
But i've delete it, can someone send it to me please ?
Replies (11)
Message 2 of 12
Message 3 of 12
DarrenP
its looking for the install files
you will need to download & extract the files again to that location
DarrenP
Message 4 of 12
just curios where the OP needs to go to find the appropriate resources?  If not AVA; Where/how?
Message 5 of 12
DarrenP
ava or their autodesk account
DarrenP
Message 6 of 12
Basam.Yousif
Can someone please just upload this file here?
Thanks!
Message 7 of 12
@Basam.Yousif
C:\Autodesk\Revit_2019_G1_Win_64bit_Trial_dlm\x64\RVT
Message 8 of 12
JanisGrf
BTW - got the same problem but there was RVT.msi missing as I tried to reinstall Revit ... and found the missing file in: C:\Autodesk\{A42C7897-B448-4717-A23B-48C7A99E9EB5}\image\RVT_2023_en-US\x64\RVT where the installation unzips from installer... that fixed the problem.
Message 9 of 12
Sandra.Brzeska
Observer
Observer
Thanks for this!!!
Message 10 of 12
201803709
Observer
Observer
GRACIAS
Message 11 of 12
josephandersonacevedoalvino
Observer
Observer
Para que de resuelva el problema, tienes que desinstalar el Revit que cuentas desde el panel de control de tu ordenador, si en caso no pudiera desinstalar: prueba con la pagina de Elimine Autodesk. 👈
Una vez realizada la desinstalación,  instala la versión del RVT.
Fig. 01: Vista del Problema
Message 12 of 12
Basam.Yousif
Not a good idea!
Do not uninstall Revit because it may be very difficult to reinstall. Do that only as last resort when nothing else works.
Modern versions of Revit (2021 and after) are almost impossible to reinstall. You have been warned 😁
