I would like help to understand how to solve:
When generating STL file does it show objects or elements that do not belong to revit in the original project? Image:
In red, an apparently lost object from my original project (in blue)
Gelöst! Gehe zur Lösung
Gelöst von Marielen_. Gehe zur Lösung
@Marielen_ wrote:STL file does it show objects or elements that do not belong to revit
Have you much experience with the STL Exporter -- or exporting in general?
I have experience in exporting through the plug-in installed in revit, I know that the elements must be in coordinates. How relevant is your question to solving the problem?
As I disabled all hidden modes, I found that this happens when I set the option "export in shared coordinates"; when I don't choose that option, that ladder doesn't appear.
@Marielen_ wrote:As I disabled all hidden modes, I found that this happens when I set the option "export in shared coordinates"; when I don't choose that option, that ladder doesn't appear.
What "ladder" are you talking about? What "hidden modes"?
