RVT 2019 Library - Show Label
1 ANTWORT 1
Nachricht 1 von 2
310 Aufrufe, 1 Antwort
In the new RVT 2019 Families, every time you insert a family from the folder a lovely label pops up.
You are able to go in after you select the family and edit type - under Graphics turn off show label. But is there a way to set this as a default??
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
You can edit the families and turn off the label visibility permanently by enter 1=0 in the formula box of that label's visibility parameter. Or simply just delete the label itself.
