Rveti LT- missing floor and options pallet
kristina_frlajsova
Observer Observer
kristina_frlajsova
Observer
Observer
in my Revit LT aren´t visiable floor plans pallets and properties pallets despite that are checked in users interfaces. I think that problem is that I  was worked on big screen last time and now I´m work just on laptop. Do you have some ideas how solve it? But without use big screen of corse 😄
imankassab2015
Press pp for properties pallet or even ctrl+1 like Autocad
And if the Project Browser is not visible, you can right-click anywhere in the application window and select Browsers > Project Browser. If you are using dual monitors, the Project Browser might be on the second monitor, so try switching to a single monitor setup or dragging the Project Browser from the second monitor to the main window.
Accept or like my answer if it helps you
kristina_frlajsova
Observer
Observer
Thank you for your advice.
It was necessary connect with monitor and manually move pallets on the laptom screen. Without connecting with monitor nothing worked.
