RTX A2000 is this compliant with Revit 2021 and revit 2022
1 ANTWORT 1
Nachricht 1 von 2
support
861 Aufrufe, 1 Antwort
we are looking at purchasing some new Engineering Pc's and most standard laptops are including the NVIDIA RTX A2000 4GB GPU. I donot see this particular card list on the Revit approval of cards.  Will this card work for my Revit user and general stability, or are they going to have issues?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: support
It is a low-end RTX but should be okay unless your models are above a half a GB.  And don't worry if a card is not in the certified/tested list from Autodesk.  They can only test so many and the ones listed there are often not worth the cost.
