RPC's are not working in Revit Architecture 2017
24 ANTWORTEN 24
GELÖST
Nachricht 1 von 25
3426 Aufrufe, 24 Antworten
I just installed Revit 2017 from 2015, so I loaded a previous project to see the new rendering capabilities and none of the trees or people are rendering, In fact most of them just show as blocks or cubes. I even loaded a new project and new families straight from the 2017 templates folders and I still get the same results. I believe it has to do with running previous versions of Revit on the computer, yes I installed 2017 before removing 2015 I've attached files to help clarify things
24 ANTWORTEN 24
Nachricht 2 von 25
aRcHiTeCt.JM
als Antwort auf: Anonymous
You need to copy again your entire RPCs library in REVIT 2017.
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2017\assetlibrary_base.fbm\RPCs
If you don't have the RPCs folder... create one and copy-paste all content
Then everything will be alright.
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 25
als Antwort auf: aRcHiTeCt.JM
This didn't work, all the files seem to be there...
Nachricht 4 von 25
aRcHiTeCt.JM
Then maybe:
That's because Archvision did not release the 2017 version of their products compatible with Revit 2017....
for the current 2016 release and its predecessors see THIS LINK HERE
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 5 von 25
I forgot to mention that im just using the stock RPC's that come with revit. it seems to me that the link in revit is somehow broken to the location of the files. or maybe it has to do with the registry of the computer...im working on windows 10.
Nachricht 6 von 25
Try reloading all the RPC trees from the 2017 library...
I just tried it with my 2017 (on Windows 10) and it works just fine.
Nachricht 7 von 25
I uninstalled Revit completely and reinstalled and not its saying "rendering feature are currently disabled. you must install the rendering library to use rendering features"
I've uninstalled and reinstalled Revit 3 times since then including everything associated with Revit and i still get this message...
Nachricht 8 von 25
Sounds like your material libraries are not getting installed.
Nachricht 9 von 25
aRcHiTeCt.JM
go to:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
or... are you installing REVIT 2017 connected online?
because for all libraries to be downloaded you need to be connected.
don't use firewall...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 10 von 25
ive downloaded it to my harddrive then im installing from there
Nachricht 11 von 25
Hi, could you solve the problem with the renderings? I've exactly the same problem.
Cubes instead trees and people.
Thank you
Nachricht 12 von 25
awalker123
I am not sure what you mean by "You need to copy again your entire RPCs library in REVIT 2017" copy what again? I copied it, now what?
The library is in this location already C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2017\assetlibrary_base.fbm\RPCs
I don't need to create it.
The trees show up as gray blocks.
Please help!
Nachricht 13 von 25
als Antwort auf: awalker123
Has anyone solved this issue? I´m having the same problem here....RPC files are installed, but trees oly show as white boxes
Nachricht 14 von 25
bhpka
I have the same problem. Has this issue ever been fixed?
Nachricht 15 von 25
bhpka
Copy from where??
Nachricht 16 von 25
melissaJCNY4
I'm having the same issue...did anyone find a solution for this?
Nachricht 17 von 25
als Antwort auf: melissaJCNY4
With 2017 I installed this and it worked,,,
Nachricht 18 von 25
melissaJCNY4
Thank you. I tried that, and it didn't fix my problem unfortunately.
Nachricht 19 von 25
Nachricht 20 von 25
melissaJCNY4
Yes. I installed and updated and it still did not work/change the plantings.
