RPC entourage - custom make in Revit - how?
36 ANTWORTEN 36
GELÖST
Nachricht 1 von 37
ro
7393 Aufrufe, 36 Antworten
Hello Revit World,
Is there a way to freely add images and customise RPC entourage using Revit?
I don't want to use Envision, Archivision or any other third party software.
RO
36 ANTWORTEN 36
Nachricht 2 von 37
als Antwort auf: ro
Nachricht 3 von 37
ro
als Antwort auf: barthbradley
Thanks again barthbradley,
Unless I am missing something, your link describes how to customise RPC content using enscape. I don't want to use third party software, just Revit.
Is there a way to just do this using Revit? Specifically, customising images?
Regards
RO
Nachricht 4 von 37
als Antwort auf: ro
Maybe I'm not understanding what you want to do? Sounds like you want to create custom Rich Photorealistic Content (RCP) without Archvision.  That's like saying you want to create a Revit content without Revit.  How would you "convert" your images into RPCs?   Maybe that's the crux of what you are asking -- that is, if there's another application to use to create RCPs.  Not to my knowledge.  What's wrong with using Autodesk's partner; Archvision?
Nachricht 5 von 37
ro
Hi barthbradely,
I installed Archivision within Revit and the dashboard. Neither offer the full flexibility I am seeking. Perhaps they do if you buy them. The add-in doesn't work at all. The dashboard has some items relevant to me but they are watermarked and I can't create my own without buying that software.
I don't understand the limitation you describe, I am asking how to convert images into RCP's, not how to do it with Archivision. Revit comes with an RCP family by default. I want to use it. Can anybody tell me how? Has Autodesk built in this limitation?
RO
Nachricht 6 von 37
als Antwort auf: ro
It is not necessary to install Archvision Dashboard to use the default RPC Revit Content. Just open up an OOTB RCP Family, such as RPC Plant - Tropical.rfa.  Then open the Family Types dialog box and scroll down to and expand Identity Data and check out Render Appearance Properties and Render Appearances .
...set Class to All and be prepared to have your mind blown by the amount of free RCP content there is.  See how much work I just saved you.  Smiley (zwinkernd)
...BTW: RPC was invented by Archvision.
Nachricht 7 von 37
ro
Thanks barthbradley,
I paid a lot of money for the 'free content'. The images are more like teasers. I don't want any of them. I want to create my own content with my own images etc. Is this possible?
Regards
Rowan
Nachricht 8 von 37
als Antwort auf: ro
Yes.
https://enscape3d.com/best-practices-custom-rpc-content/
...you know, I'm staring to wonder if your library is installed correctly, because I find it odd that you would characterize the free RPC Content as "teasers".
Nachricht 9 von 37
ro
Hi barthbradley,
You are being very patient.
You are directing me to Enscape and Archivision. I don't want to use any third party applications.
I want to know how to insert an image into an RPC in Revit.
RO
Nachricht 10 von 37
als Antwort auf: ro
You can't.
Nachricht 11 von 37
aRcHiTeCt.JM
als Antwort auf: ro
... yes there is a way
... you can NOT make it like a native REVIT RPC
... as @barthbradley  is saying ... no matter what you need to use at least Archvision
... even if you don't like it
.... go to this link
... https://archvision.com/the-power-to-create-rock-on-with-rpc-creator/
.... download the RPC Creator and create a whatever you want... its free!
... I have been using those for years and it is perfect for that matter
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 12 von 37
als Antwort auf: aRcHiTeCt.JM
We had over 1000+ RPC "people" at a previous company...and because our material images were hosted on our servers only they were pretty much worthless to other companies that might try to take them.
Nachricht 13 von 37
Nachricht 14 von 37
ro
Hello again people of Revit ,
Just to clarify, I don't want to know about Archivision, Enscape or any third party softwares.
I'm wandering how to use Revit to may custom RCP entourage. I want to know how to insert my own images.
Was there a time that you could customise your own RCP in Revit? If so, which version?
Are there any workarounds? Any hacks? Where do the images reside? Autodesk, can you rectify this omission if it is one?
Regards
RO
Nachricht 15 von 37
ro
als Antwort auf: ro
Incidentally, I've tried installing archivision. It doesn't work for me. Attached is what I get.
Nachricht 16 von 37
als Antwort auf: ro
Regards
RO
@ro : I think you are failing to understand "RPC".  "RPC" IS Archvision. It's their baby.  They own it.  They partner with Autodesk, just like Oracle partners with Microsoft.   If you don't want to use Archvision, then forget "RPC".  Figure out how you can create your own photo-realistic content to use in Revit -- a  BIM* software.
* Building Information Modeling (BIM) is an intelligent 3D model-based process that gives architecture, engineering, and construction (AEC) professionals the insight and tools to more efficiently plan, design, construct, and manage buildings and infrastructure.
Good Luck.
Nachricht 17 von 37
als Antwort auf: ro
Dashboard is an RPC Content Manager.  Do you have any RPC content to manage? If not, that looks exactly right.
Nachricht 18 von 37
constantin.stroescu
als Antwort auf: ro
If you want to make an easy to use entourage library you can do it as I do it currently , by using a Mass Element Surface mapped with a bitmap with alpha mask.....
Here are some example how they look in rendering ( the render was made in Autodesk Cloud) - people and trees...
Constantin Stroescu
Nachricht 19 von 37
Love these Artsy-Farty families!
Thanks again for turning me on to them,  @constantin.stroescu.
Smiley (zwinkernd)
Nachricht 20 von 37
It's based on scanned hand sketches with an alpha mask made in Photoshop and mapped to a Mass Surface..I use them mainly in conceptual design phase that has to look as something made it up on the spot...
Constantin Stroescu
