hellow i have a problem with my route analysis.
In the route analysis settings is the door family checked so the route path should go through the door, but it doesn't
I think its something with the door family itself because when I load a default door and close the door it works. Anyone an idea what it could be?
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
can you upload the door family you're having the issue with?
Howard Munsell
hellow i found the problem, in the door family there are generic models so thats why.
Interesting, nested generic model families in the door family were preventing it from being used. if their location was blocking the minimum pass thru size, I guess that makes sense.
Good catch ![]()
Howard Munsell
