How to get a roundup column which picks up on the calculated total displayed and not rounding up each area individually first and them add them all up.
In the example below, I want to be able to roundup the 8.1m2 into 9 m2, not rounding up each 4.1m2 into 5m2 and show 10m2
Thank you
J
Gelöst! Gehe zur Lösung
Gelöst von Kimtaurus. Gehe zur Lösung
Revit always calculates using the original individual values.
So it's not using the total of the rooms to calculate with, but the values per instance.
I doubt that what you want can be achieve in Revit, at least not automatically, maybe with Dynamo.
Or export your schedule to Excel.
Thank you. Was trying to check if there was a workaround for this.
I need it to roundup in a way so that if total grouped area = 8.1m2 it rounds to 9.0m2
