Rounding up Total
Rounding up Total
jason.harcourtE9D7U
Message 1 of 14
Rounding up Total
jason.harcourtE9D7U
Hi All,
Trying to accurately cost timber lengths for picking and supply. have got as far as the attached but need to round the lengths up to 4800mm lengths for picking in the factory and the total cost to then calculate the rounded up qty not the exact qty.. Any suggestions? (see attached)
Replies (13)
Message 2 of 14
Are you talking about the grand totals?
Message 3 of 14
jason.harcourtE9D7U
the length qty. I want to round it up to the nearest length then have the total cost take that number for calculating the cost as we will be supplying full lengths without cutting them down
Message 5 of 14
jason.harcourtE9D7U
thankyou but not sure how that works to be honest. ?
Message 6 of 14
I added some links for you.
Basically, you need to create Calculated Parameters using formulas.  Do you follow?
Message 7 of 14
jason.harcourtE9D7U
yes just not sure how to do it
Message 8 of 14
mhiserZFHXS
I don't have Revit open so you may need to adjust syntax.
Try something like:
roundup(Total Lengths/4800)*4800
Then for pricing:
(roundup(Total Lengths/4800)*4800) * Cost
If total length is already a calculated parameter, you'll need to replace that parameter with the equation used for total length, as you can't reference a calculated parameter with another calculated parameter (which AutoDesk should really address).
Edit: Apparently you can use calculated parameters in equations. Not sure if that's new or if I was having some other issue with it last time I tried to figure it out.
Message 9 of 14
jason.harcourtE9D7U
i tried that but didnt work for some reason. have attached the file incase you can help further. Thankyou
Message 10 of 14
mhiserZFHXS
Yea it's not working because of how Revit lets you use "Count", which is really unfortunate.
You could use Dynamo to do the math and then populate another parameter. That's the best I can think of now after playing with it, unless someone else can think of something.
Message 11 of 14
To clarify, do you just want know how many 4.8 meter members you need to buy in total?
Message 12 of 14
jason.harcourtE9D7U
Yes pretty much
Message 13 of 14
Edited file.
Message 14 of 14
jason.harcourtE9D7U
ToanDN thats perfect. Thankyou so much
