Round Timber Column with Space Frame Pin Joint
slaghuis.jonathan
slaghuis.jonathan
Good day,
I am looking to model a timber column with a steel space frame pin joint kind of connection like the image attached, but I am not too sure the approach I should take. The idea is that each arm will attach and support the respective triangular beams above.   Can anyone help?
Regards
Jonathan
RDAOU
@slaghuis.jonathan
It is pretty much standard and basic.
  1. Either model it as a generic model (simple sweeps and extrusions)  and nest it into the structural column family
  2. Or model the SF as part of a pattern based structure
  3. Or model the SF as adaptive components, load into a mass and use repeaters
I would go with the first approach and the framing above use a beam system...you should find plenty of youtube tutorials as well as length posts on this forum that cover all of the above mentioned approaches
slaghuis.jonathan
Thank you for the reply. However, I am still quite new to revit and don't quite understand it. What sort of tutorials should I be looking for that will help explain the first approach.
syman2000
Have you look into Structure connection? I would start looking into those item first. Once you get familiar with it, you would dive into the complex connection like you have. Attached is a short tutorial how to work with structural and connection.
https://www.youtube.com/watch?v=5BOwfdWEL80
I would model meat and potatoes of it (e.g. the  web and chord components) via a parametric Truss Family.  You might start off by modifying an OOTB Truss, such as the Warren Truss, which is what I did in this screenshot.  Keep in mind that the top chord will attach to bottom of roof the same way Walls do.
Drill down into this link to learn more:
Trusses | Revit 2019 | Autodesk Knowledge Network
