round off
round off
BIM_Dreamer
Message 1 of 10
round off
BIM_Dreamer
how to round off this area to 17856.53 in schedule> already change the unit to .01, 001 but doesn't work. thank you
Replies (9)
Message 2 of 10
RDAOU
@BIM_Dreamer
I am not sure you will be able to round up/down the 2nd or 3rd decimals...If the GFA must be that precise, give one of an area a nudge up to get the +0.001 needed otherwise, it will round up/down based on the value of the last decimal digit
  • rounds down: if digit <= to 5
  • rounds up: if digit is >5
Rounding whole value to omit the decimals (ie: down to 17856.00  or up to 17857.00) would be possible using a calculated value
Message 3 of 10
BIM_Dreamer
thank you for your reply. i tried 2 and 3 decimal but doesn't round off. client need to be exact as .53 round off. need to have decimal number and not total whole number. thanks
Message 4 of 10
RDAOU
@BIM_Dreamer
Nudge an area boundary to increase one area by 0.001m2 and bring the decimal to .5251
Message 5 of 10
Can you show the Area with 4 or more decimals (.0001)?  I think it is less than .525 that is why is round down to.52.
Message 6 of 10
BIM_Dreamer
here. thank you
Message 7 of 10
Yep .5249 will be round down to .52, which is correct. If you want to fake it, you need to make it at least .5250 in order to round up to .53
Message 8 of 10
BIM_Dreamer
not possible there are lots of room area.
Message 9 of 10
BIM_Dreamer
where to adjust? there a lots of room area. thank you
Message 10 of 10
RDAOU
Nothing is impossible if you have the will... pick any random area and increase it slightly...just enough to make up for the 0.001m2
