Rotation problem
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
r0812124
329 Aufrufe, 2 Antworten
Rotation problem
Hey fellow Revit users,
I've recently started having the problem that I can't rotate certain families (in both Revit 2022 and 2023).
I can't seem to find any sort of pattern of when the issue occurs though.
Does anyone have an idea what might cause this problem and how I could solve it.
Thanks in advance!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: r0812124
Could be any number of explanations.  Hard to troubleshoot without knowing specifics.
One explanation might be that there is a constraint activated on the Options Bar that is preventing rotation.  When you start a Rotation, look on the Options Bar and you'll see what I'm referring to.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M....
Nachricht 3 von 3
r0812124
Thanks for your input, it seems unchecking 'disjoin' does the trick, seems a little counterintuïtive though...
